惯性载荷的问题。
浏览:135737
workbench中,本人在静态分析中对 设备施加了 5倍重力加速度的 关系载荷,软件总是报错,报错内容如下:
An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present. Please see the Troubleshooting section of the Help System for more information.
请各位大侠帮忙解决。不甚感激。
