求大神帮忙解决NCODE问题,在线急等!
浏览:128709 回答:1
这是错误日志内容,请大神帮忙一下,在线急等!
Ansys.Core.Commands.UserReadableFailureException: Update of DesignLife failed.
An error was encountered while performing the update.
Please view the Error Messages for more details.
at Ansys.DesignLifeAddin.UpdateDesignLifeCommand.Execute(IFullContext context)
at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Update of DesignLife failed.
CommandName: DesignLifeAddin.UpdateDesignLife(Container="DLSolution")
at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete(Int32 milliSecondsTimeout, Boolean exitContext)
at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update(IFullContext context, IProgressMonitor progressMonitor, DataContainerReference container, UpdateOptions updateOptions, List`1 downstream, List`1 allRemaining)
at Ansys.ProjectSchematic.Update.UpdateImpl.updateComponent(IFullContext context, UpdateTask task, String trackToken)
at Ansys.ProjectSchematic.Update.UpdateImpl.<>c__DisplayClass1d.<updateComponentAndDependencies>b__1b()
at Ansys.ProjectSchematic.Update.UpdateImpl.executeWithSelectedErrorBehaviour(Op op, UpdateTask forTask, Op opUponError)
at Ansys.ProjectSchematic.Update.UpdateImpl.updateComponentAndDependencies(UpdateTask task, Boolean& didSomething)
at Ansys.ProjectSchematic.Update.UpdateImpl.checkAndUpdateComponent(UpdateTask task, Boolean& didSomething)
at Ansys.ProjectSchematic.Update.UpdateImpl.doOutstandingTasks(IEnumerable`1 tasks, Boolean& didSomething)
--- System.InvalidOperationException: Update of the Solution component in nCode EN TimeSeries (DesignLife) failed: Update of DesignLife failed.
at Ansys.ProjectSchematic.Update.UpdateImpl.<UpdateComponents>d__0.MoveNext()
at Ansys.ProjectSchematic.Commands.UpdateComponentCommand.<Execute>d__0.MoveNext()
at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
--- Ansys.Core.Commands.CommandFailedException: Update of the Solution component in nCode EN TimeSeries (DesignLife) failed: Update of DesignLife failed.
CommandName: UpdateComponent(Component="/Schematic/Component:DLResults", AllDependencies=True)
at Ansys.ProjectSchematic.GuiOperations.UpdateComponent.Invoke(GuiOperationContext context)
at Ansys.UI.UIManager.<>c__DisplayClassb.<InvokeOperation>b__a()
at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction)
我也遇到了,解决了吗
