Data Check出现错误
浏览:127339
在Job下Data Check的时候出现这个大哥们救命啊。。。。。inp文件附上。。
Error in job Job-12: The volume of 128 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
Job Job-12: Analysis Input File Processor aborted due to errors.
