abaqus/cfd运行过程中错误解析
浏览:131102 回答:2
大家好,本人在应用abaqus/cfd时,不论是自带的例子,还是从网上找的例子,提交job运算时,总会提示如下错误:ERROR in job messaging system: Error in connection to analysisError in job ke4: The executable SMACfdMain.exe aborted with system error code 3. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job ke4 aborted due to errors.
在网上查了下,也没找到解决方法。把算例发给一同学算了下,提示和我的一样。我的版本是6.13的。
跪求各位大神不吝赐教,不胜感激!
songxiaqingchen
楼主,你好,我也出现这个问题,你解决了么?
2015年3月31日
