cfx 求解出错
浏览:172308 回答:5
****** Notice ****** |
| Newtons method failed to converge in 100 iterations. This |
| occurred while computing the following variable: |
| Variable Name : Temperature |
| Location Name : FULID |
| Mesh location : VERTICES |
| Mesh entity : |
| Last 3 Changes : 5.01272E-02 2.98919E-02 1.62209E-01 |
| Tolerance : 1.0000E-02 |
| The Newton iteration was diverging. The solver will continue |
| with the variable field as it was on the final iteration. If |
| this situation continues you might try decreasing the Newton |
| iteration under relaxation factor. This can be changed by |
| setting one of the following parameters: |
| Temperature : "Constitutive Relation Under Relaxation" |
| Pressure : "Newton Pressure Under Relaxation" |
| for your mixture using the definition file editor.
算到104步左右就不算了,或者出错显示,the ansys cfx solver exited with return code1. no result file has been created. 每次都是在80步,或104步左右出错或停止运算。这是什么原因啊,重画网格还是一样,出错还是一样,试了好几十次了。。请教各位高手,是我网格有问题还是 cfx设置有错?跪求啊,,
| Mesh entity : |
