求助:双椭球热源表格加载中其表格数据怎么来的?
浏览:50033 回答:2
如*DIM,%TABLENAME%,TABLE,7,38,1,,,,%TABLECSYS%
*SET,%TABLENAME%(0,0,1),0.0,-999
*SET,%TABLENAME%(2,0,1),0.0
*SET,%TABLENAME%(3,0,1),%TABLE_ROW1(1)%
*SET,%TABLENAME%(4,0,1),%TABLE_ROW2(1)%
*SET,%TABLENAME%(5,0,1),%TABLE_ROW3(1)%
*SET,%TABLENAME%(6,0,1),%TABLE_ROW4(1)%
*SET,%TABLENAME%(7,0,1),%TABLE_ROW5(1)%
*SET,%TABLENAME%(0,1,1),1.0,-1,16,3,0,0,0
*SET,%TABLENAME%(0,2,1),0.0,-2,0,6,0,0,-1
*SET,%TABLENAME%(0,3,1),0.0,-3,0,1,-2,3,-1
*SET,%TABLENAME%(0,4,1),0.0,-1,0,1,-3,3,17
*SET,%TABLENAME%(0,5,1),0.0,-2,0,1,-1,3,18
*SET,%TABLENAME%(0,6,1),0.0,-1,0,0,0,0,0
*SET,%TABLENAME%(0,7,1),0.0,-3,0,1,0,0,-1
*SET,%TABLENAME%(0,8,1),0.0,-4,0,1,-1,2,-3
*SET,%TABLENAME%(0,9,1),0.0,-1,0,2,0,0,2
*SET,%TABLENAME%(0,10,1),0.0,-3,0,1,2,17,-1
*SET,%TABLENAME%(0,11,1),0.0,-1,0,2,0,0, 19
*SET,%TABLENAME%(0,12,1),0.0,-5,0,1,19,17,-1
*SET,%TABLENAME%(0,13,1),0.0,-1,0,1,-3,4,-5
*SET,%TABLENAME%(0,14,1),0.0,-3,0,2,0,0,3
*SET,%TABLENAME%(0,15,1),0.0,-5,0,1,3,17,-3
*SET,%TABLENAME%(0,16,1),0.0,-3,0,2,0,0,20
*SET,%TABLENAME%(0,17,1),0.0,-6,0,1,20,17,-3
*SET,%TABLENAME%(0,18 ,1),0.0,-3,0,1,-5,4,-6
*SET,%TABLENAME%(0,19,1),0.0,-5,0,1,-1,1,-3
*SET,%TABLENAME%(0,20,1),0.0,-1,0,2,0,0,4
*SET,%TABLENAME%(0,21,1),0.0,-3,0,1,4,17,-1
*SET,%TABLENAME%(0,22,1),0.0,-1,0,2,0,0,21
*SET,%TABLENAME%(0,23,1),0.0,-6,0,1,21,17,-1
*SET,%TABLENAME%(0,24,1),0.0,-1,0,1,-3,4,-6
*SET,%TABLENAME%(0,25,1),0.0,-3,0,1,-5,1,-1
*SET,%TABLENAME%(0,26,1),0.0,-1,0,3,0,0,-3
*SET,%TABLENAME%(0,27,1),0.0,-5,0,1,-1,3,-3
*SET,%TABLENAME%(0,28,1),0.0,-1,0,1,-4,3,-5
*SET,%TABLENAME%(0,29,1),0.0,-1,7,1,-1,0,0
*SET,%TABLENAME%(0,30,1),0.0,-3,0,1,-2,3,-1
*SET,%TABLENAME%(0,31,1),0.0,-1,0,1,20,3,21
*SET,%TABLENAME%(0,32,1),0.0,-2,0,1,-1,3,19
*SET,%TABLENAME%(0,33,1),0.0,-1,0,3.14,0,0,-2
*SET,%TABLENAME%(0,34,1),0.0,-4,0,1,-2,3,-1
*SET,%TABLENAME%(0,35,1),0.0,-1,16,3.14,0,0,0
*SET,%TABLENAME%(0,36,1),0.0,-2,0,1,-4,3,-1
*SET,%TABLENAME%(0,37,1),0.0,-1,0,1,-3,4,-2
*SET,%TABLENAME%(0,38,1),0.0,99,0,1,-1,0,0
表格中*SET后面的数据怎么得来的?求各位大神释疑!!!
完整程序见附件!
vicly2012
没有人光顾啊:t(
2013年11月23日
