钢支撑框架的接触(焊接我定义为绑定)
浏览:163329 回答:1
各位大神,我现在在做钢框架支撑,给框架一个侧向力,得到框架的侧向位移,但是我建的这个模型,问题好多
For *tie pair (assembly_beamlinght-assembly_sidec1-up), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_board1up-assembly_beamunderl), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly_sidec1-up,assembly_board1linght) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly_sidec1-up-assembly_board1linght), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly_braceup,assembly_brace1) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly_braceup-assembly_brace1), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_brace2-assembly_braceunder), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly_sidec2-under,assembly_board2right) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly_sidec2-under-assembly_board2right), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_sidec2-up-assembly_beamright), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Slave node 14 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 15 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 17 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 18 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 341 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 342 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 343 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 344 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 345 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 346 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 347 instance side-column-1 will not be tied to the master surface assembly_board1linght. The distance from the master surface is greater than the position tolerance value.
Slave node 26 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 28 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 40 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 42 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 1015 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 1016 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 1017 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 1018 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 1019 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 1020 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 1021 instance side-column-2 will not be tied to the master surface assembly_board2right. The distance from the master surface is greater than the position tolerance value.
Slave node 2 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 3 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 5 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 6 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 43 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 44 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 45 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 46 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 47 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 48 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
Slave node 49 instance side-column-2 will not be tied to the master surface assembly_beamright. The distance from the master surface is greater than the position tolerance value.
3990 nodes are either missing intersection with their respective master surface or are outside the adjust zone. The nodes have been identified in node set WarnNodeMissMasterIntersect.
Boundary conditions are specified on inactive dof of 4 nodes. The nodes have been identified in node set WarnNodeBCInactiveDof.
焊接我是采用绑定连接的,但是有块连接板上侧和左侧都有绑定
lgswxj620
遇到同样问题。。。。楼主问题怎么解决没??
2015年4月16日
