不出云图(For element 1 there are only 1 (out of 8 expected)
浏览:71727 回答:1
Fe-safe新手,做一个橡胶疲劳分析(有SN曲线),出现以下错误,出不了云图:For element 1 there are only 1 (out of 8 expected) values, -1 will be used.
There were 7 missing values when exporting contour LOGLife-Repeats. The missing values have defaulted to -1.
There were 7 missing values when exporting contour FOS@Life=5E4-Repeats. The missing values have defaulted to -1.
英语字面意思能明白,但是是却哪些参数,如何处理?求大神解答
尘埃落定a12
完成求解没有?没遇到过这种问题
2014年5月16日
