求高手,abaqus几个问题的解决方法
浏览:56521
1.
For *tie pair (assembly_s_surf-18-assembly_m_surf-1), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
2.
Slave node 2 instance bodyring will not be tied to the master surface assembly_m_surf-1. The distance from the master surface is greater than the position tolerance value.
3.
5967 nodes are either missing intersection with their respective master surface or are outside the adjust zone. The nodes have been identified in node set WarnNodeMissMasterIntersect.
4.
40 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
