熱分析
浏览:133955
請問是哪裡沒設定,才會出現下列errors?!
Temperature at 1 nodes has fallen below absolute zero. Increment will be attempted again with a new time increment. The nodes have been identified in node set WarnNodeTempBelowZeroStep1Inc1585.
