桩土共同作用分析
浏览:171636 回答:1
地应力平衡后,出现这个错误:The executable pre.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.有谁知道这应该是哪出错了吗
红日当空q3120210076
可以参考我的技术邻视频如何来解决桩土地应力平衡问题
2020年3月29日
