求助帖
浏览:52837
求助帖的图1 在我先添加完第一个行星齿轮后仿真,轮系能够正常运转,只要再添加一个就出错,不能仿真了,不知道为什么,有人帮忙看看吧?先谢谢了。 错误如下:
错误: At time 1.000000E-01 the Kinematic Displacement solution matrix is singular.
The Kinematic solution can not proceed.
Possible causes:
Check to see if model has reached a locked position.
Check for redundant constraints. Adams/Solver may have removed the wrong
constraint and caused the model to become inconsistent.
错误: Simulation failure detected.
