【MSC NASTRAN】关于没有xdb文件生成
浏览:113808 回答:3
在patran中调用nastran进行分析之后,没有xdb文件生成。直接打开nastran,对.db文件分析之后,依然没有xdb文件生成。有没有哪位知道是怎么回事打开生成的f06文件之后,发现有这样一条语句:
*** USER FATAL MESSAGE 108 (SCA.MDSolver.Obj.InputFile.InputFile::read)
The input stream data file h:/������/����Ԫ/����ҵ/1.bdf does not exist.
我在h盘的一个文件夹里明明用patran导出一个1.dbf文件的,为什么递交nastran分析时会出错?
这是其他的报错:
*** USER WARNING MESSAGE 209 (SCA.MDSolver.Io.AccessAccess.AccessAccess::isEchoSortRequested)
No stream input file has been converted to its binary form using StreamToBinary.
The ECHO data returns will all be false.
*** SYSTEM FATAL MESSAGE 501 (SCA.MDSolver.Io.AccessAccess.AccessDatabase::open)
Error 1 occured while attempting to open database ./1.IFPDAT.
*** SYSTEM FATAL MESSAGE 3001 (IFPDR)
THE INPUT DATA BLOCK NAMED IFPFLAG AT POSITION 1 DOES NOT EXIST.
USER INFORMATION: THIS ERROR IS CAUSED BY ONE OF THE FOLLOWING:
1. THE DATA BLOCK WAS NEVER CREATED.
2. THE DATA BLOCK WAS DELETED.
3. THE DATA BLOCK IS SPECIFIED ON A TYPE STATEMENT IN THE CURRENT SUBDMAP OR A HIGHER SUBDMAP
BUT THE CURRENT QUALIFIER VALUES DO NOT MATCH
THE QUALIFIER VALUES OF THE DATA BLOCK(S) ON THE DATABASE.
USER ACTION: 1. IF YOU ARE EXECUTING AN MSC.SOFTWARE SUPPLIED SOLUTION SEQUENCE AND NOT USING THE
ALTER EXECUTIVE CONTROL STATEMENT, THEN CHECK FOR BULK DATA AND/OR CASE CONTROL INPUT
ERRORS. IF NO ERRORS CAN BE FOUND, THEN CONTACT MSC.SOFTWARE CLIENT SUPPORT.
2. IF YOU ARE EXECUTING A DMAP PROGRAM NOT SUPPLIED BY MSC.SOFTWARE, THEN FOR DEBUGGING PURPOSES
INSERT STATEMENT DIAGON(20) BEFORE THE MODULE SHOWN ABOVE.
这是其他的报错:
