关于abaqus架体用trussT3D2为什么不能模态分析而用beam单元却能分析
浏览:146313 回答:2
提示 :Three factorizations in a row failed. Check the model. It is possible that the model contains the kinematic coupling definition set up in a way that a degree of freedom has neither mass nor stiffness.
怎么解决?!我只想用铰接的
mai121659481
好沮丧:<
2014年9月22日
