拓扑了好几天就是出不来,要死了- -!
浏览:11352
A fatal error has been detected during input processing:
*** ERROR # 6000 *** One of the vectors defined on ***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN *****
************************************************************************Errors reported during program execution
hwsolver.mesg output from the solver:==============================
Solver FAILED
optistruct:: Solver run finished.
