ansys 错误原因分析!!!!
浏览:7978 回答:2
During this session the elapsed time exceeds the CPU time by 712%.
Often this indicates either a lack of physical memory (RAM) required
to efficiently handle this simulation or it indicates a particularly
slow hard drive configuration. This simulation can be expected to run
faster on identical hardware if additional RAM or a faster hard drive
configuration is made available. For more details, please see the
ANSYS Performance Guide which is part of the ANSYS Help system.
这是什么原因产生的啊
zjzgjy1103
有大神见过这种问题吗
2015年3月23日
zjzgjy1103
如何解决呢
2015年3月23日
