复合地基 桩土接触地应力平衡不了 遇到下面错误
浏览:12506 回答:1
A geostatic procedure with maximum displacement tolerances is supported only for continuum elements with pore pressure degree of freedom and the corresponding stress/displacement continuum elements. In general, the use of other elements with this procedure may lead to poor convergence or no convergence of the analysis.
红日当空q3120210076
可以参考我的技术邻视频如何来解决桩土地应力平衡问题
2020年3月29日
