请问做顺序耦合热应力计算出错问题
浏览:15604
Both the file option and the data line format option are used for the *temperature in the same step. For a given node the values given on the data line will take precedence if op=mod parameter is specified or if op=new parameter is used to specify new values for the removed field
出现这个错误是为什么
做完热传导以后replace分析步后换网格类型么
