请教一个变压器仿真的问题
浏览:4656 回答:1
哪位高手能帮我看看为什么我的变压器仿真结果二次侧电压图形是这样的,我铁芯是用的非线性的BH曲线
指令如下:
/title, TEsT_1
/vie,1,2,-1,3
/pnu,mat,1
/num,1
pi=acos(-1)
! *** Model parameters
a_core=0.072 ! core cross-section width
w_core=0.090 ! overall core width
h_core=0.075 ! overall core height
b_core=0.030
d_core=0.004 !漏磁冲片总厚度
n_l=4 !漏磁冲片片数
Air_core=0.0005 !硅钢片间距
d_l=(d_core-(n_l-1)*air_core)/n_l !漏磁冲片每片厚度
N_core=20 !硅钢片数
S_core=(a_core-(n_core-1)*air_core)/n_core !硅钢片厚度
w_coil=0.013 ! 线圈宽度
d_coil=0.003 ! 线圈与铁芯距离
h_p_coil=0.015 ! height, primary coils
h_s_coil=0.022 ! height, second coils
d_air=0.001 ! 气隙间距
h_coil=h_p_coil+h_s_coil+d_air*4+d_core
d_dmn=0.020 ! 空气范围值
esz1=a_core/12 ! element size, components
esz2=a_core/12 ! element size, surrounding domain
mu_core=500000 ! core permeability
! *** primary coil
Np=126 ! # of turns
Rp=6 ! dC resistance (ohms)
care_p=w_coil*h_p_coil
volu_p_c=pi*((w_coil+d_air)**2-d_air**2)*h_p_coil
volu_p_b=(2*a_core+4*d_coil)*care_p
volu_p_b1=(2*b_core+4*d_air)*care_p
Vp=220 ! voltage (V)
! *** secondary coil
Ns=1260 ! # of turns
Rs=200 ! dC resistance (ohms)
care_s=w_coil*h_s_coil
volu_s_c=pi*((w_coil+d_air)**2-d_air**2)*h_s_coil
volu_s_b=(2*a_core+4*d_coil)*care_s
volu_s_b1=(2*b_core+4*d_air)*care_s
R=1e3 ! resistance attached to the secondary coil
symm=2 ! symmetry factor
! --- Excitation parameters
Vp=220*sqrt(2) ! voltage (V)
ncyc=1.0 ! number of cycles
nsubT=40 ! number of time steps per cycle
frqncy=50 ! frequency, Hz
! --- Derived parameters
T=1/frqncy
! time period
tend=ncyc*T ! solution time
nsubs=nsubT*ncyc ! total number of time steps
*dim,U,table,nsubs
*do,i,0,nsubs
U(i,1)=Vp*sin(2*pi*frqncy*(i/nsubs)*T)
U(i,0)=(i/nsubT)*T
*enddo
/axl,x,Time (s)
/axl,y,Volt (V)
*vplo,U(1,0),U(1,1)
/nopr
! *** Geometry
/pREp7
vsel,none ! core
bloc,-w_core/2,w_core/2,-h_core/2,h_core/2,-S_core,0
cm,scrap1_v,volu
vsel,none
bloc,-w_coil-b_core/2-2*d_air,-b_core/2,-h_coil/2,h_coil/2,-S_core,0
bloc,b_core/2,b_core/2+w_coil+2*d_air,-h_coil/2,h_coil/2,-S_core,0
cm,scrap2_v,volu
cmse,s,scrap1_v
cmse,a,scrap2_v
vsbv,scrap1_v,scrap2_v
Vgen,N_core/2,all,,,,,-Air_core-S_core
vsel,none
bloc,-w_coil-b_core/2-d_air,-b_core/2-d_air,2*d_air+h_p_coil-h_coil/2,2*d_air+h_p_coil+d_l-h_coil/2,-a_core/2,0
bloc,b_core/2+d_air,b_core/2+w_coil+d_air,2*d_air+h_p_coil-h_coil/2,2*d_air+h_p_coil+d_l-h_coil/2,-a_core/2,0
Vgen,n_l,all,,,,Air_core+d_l,
vsel,all
cm,core_v,volu
vatt,2,2,2
wpcs,-1,0 ! primary coil left
wpof,-b_core/2,d_air-h_coil/2,-a_core/2-d_coil
wpro,,-90
cswp,11,1
wpcs,-1,0 ! primary coil right
wpof,b_core/2,d_air-h_coil/2,-a_core/2-d_coil
wpro,,-90
cswp,12,1
wpcs,-1,0 ! second coil left
wpof,-b_core/2,h_coil/2-d_air,-a_core/2-d_coil
wpro,,-90
cswp,13,1
wpcs,-1,0 ! second coil right
wpof,b_core/2,h_coil/2-d_air,-a_core/2-d_coil
wpro,,-90
cswp,14,1
csys
wpcs,-1,0
! second coil
vsel,none ! second coil left block
bloc,-w_coil-b_core/2-d_air,-b_core/2-d_air,h_coil/2-d_air-h_s_coil,h_coil/2-d_air,0,-a_core/2-d_coil
vatt,4,6,4,0
vsel,none
! second coil right block
bloc,w_coil+b_core/2+d_air,b_core/2+d_air,h_coil/2-d_air-h_s_coil,h_coil/2-d_air,0,-a_core/2-d_coil
vatt,4,8,4,0
vsel,none
! second coil behind block
bloc,-w_coil-d_air*2,w_coil+d_air*2,h_coil/2-d_air-h_s_coil,h_coil/2-d_air,-a_core/2-d_coil-d_air-w_coil,-a_core/2-d_coil-d_air
vatt,4,7,4,0
wpcs,-1,13
! second coil left cylinder
vsel,none
cyli,d_air,w_coil+d_air,-h_s_coil,0,90,180
vatt,4,9,4,13
wpcs,-1,14
! second coil right cylinder
vsel,none
cyli,d_air,w_coil+d_air,-h_s_coil,0,0,90
vatt,4,10,4,14
vsel,none ! primary coil left block
bloc,-w_coil-b_core/2-d_air,-b_core/2-d_air,-h_coil/2+d_air+h_p_coil,-h_coil/2+d_air,0,-a_core/2-d_coil
vatt,3,1,3,0
vsel,none ! primary coil right block
bloc,w_coil+b_core/2+d_air,b_core/2+d_air,-h_coil/2+d_air+h_p_coil,-h_coil/2+d_air,0,-a_core/2-d_coil
vatt,3,3,3,0
vsel,none ! primary coil behind block
bloc,-w_coil-d_air*2,w_coil+d_air*2,-h_coil/2+d_air+h_p_coil,-h_coil/2+d_air,-a_core/2-d_coil-d_air-w_coil,-a_core/2-d_coil-d_air
vatt,3,2,3,0
wpcs,-1,11
vsel,none ! primary coil left cylinder
Cyli,d_air,w_coil+d_air,h_p_coil,0,90,180
vatt,3,4,3,11
wpcs,-1,12
vsel,none ! primary coil right cylinder
Cyli,d_air,w_coil+d_air,h_p_coil,0,0,90
vatt,3,5,3,12
alls
cm,keep_v,volu
wpcs,-1,0 ! surrounding domain
vsel,none
bloc,-w_core/2-d_dmn,w_core/2+d_dmn,-h_core/2-d_dmn,h_core/2+d_dmn,-a_core/2-d_dmn*2,0
cm,scrap_v,volu
cmse,all
vsbv,scrap_v,keep_v,,dele,keep
cmse,u,keep_v
cm,air_v,volu
vatt,1,,1
alls
vplo
! *** FE model
et,1,236 ! air
mp,murx,1,1
et,2,236 ! core
Tb,bh,2,,40
Tbpt,,100,0.46512
,,200,0.72993
,,300,0.9009
,,400,1.0204
,,500,1.1086
,,600,1.1765
,,700,1.2302
,,800,1.2739
,,900,1.3
,,1000,1.3405
,,1400,1.4257
,,1800,1.4778
,,2200,1.5131
,,2600,1.5385
,,3000,1.5576
,,3400,1.5726
,,3800,1.5847
,,4200,1.5945
,,4600,1.6028
,,5000,1.6098
,,7000,1.6332
,,9000,1.6465
,,11000,1.6551
,,13000,1.6611
,,15000,1.6656
et,3,236,2 ! primary coil
mp,murx,3,1
r,1,care_p,Np,volu_p_b/2,0,0,1
rmore,Rp*volu_p_b/(volu_p_c+volu_p_b1+volu_p_b)/2,symm
r,2,care_p,Np,volu_p_b1,-1,0,0
rmore,Rp*volu_p_b1/(volu_p_c+volu_p_b1+volu_p_b),symm
r,3,care_p,Np,volu_p_b/2,0,0,-1
r,4,care_p,Np,volu_p_c/2,0,1,0
rmore,Rp*volu_p_c/(volu_p_c+volu_p_b1+volu_p_b)/2,symm
r,5,care_p,Np,volu_p_c/2,0,1,0
et,4,236,2 ! secondary coil
mp,murx,4,1
r,6,care_s,Ns,volu_s_b/2,0,0,-1
rmore,Rs*volu_s_b/(volu_s_c+volu_s_b1+volu_s_b)/2,symm
r,7,care_s,Ns,volu_s_b1,1,0,0
rmore,Rs*volu_s_b1/(volu_s_c+volu_s_b1+volu_s_b),symm
r,8,care_s,Ns,volu_s_b/2,0,0,1
r,9,care_s,Ns,volu_s_c/2,0,-1,0
rmore,Rs*volu_s_c/(volu_s_c+volu_s_b1+volu_s_b)/2,symm
r,10,care_s,Ns,volu_s_c/2,0,-1,0
! *** Mesh
numm,kp,1e-8,1e-8
esiz,esz1
vsel,s,mat,,3,4
vmes,all
vsel,s,mat,,2
vswe,all
vsel,s,mat,,1
msha,1
Smrtsize,6
vMESH,ALL
alls
! *** boundary conditions and loads
Csys ! flux parallel exterior
asel,s,loc,y,-h_core/2-d_dmn
asel,a,loc,y,h_core/2+d_dmn
asel,a,loc,x,-w_core/2-d_dmn
asel,a,loc,x,w_core/2+d_dmn
asel,a,loc,z,-a_core/2-d_dmn*2
asel,a,loc,z,0
da,all,az
vsel,s,mat,,3 ! primary coil
alls,belo,volu
cp,1,emf,all
cp,2,volt,all
nd_p=ndnext(0)
alls
vsel,s,mat,,4 ! secondary coil
alls,belo,volu
cp,3,emf,all
cp,4,volt,all
nd_s=ndnext(0)
alls
d,nd_p,volt,%u%
! *** Circuit
et,5,124,0 ! resistor connected to the secondary coil
r,11,R
*get,nmax,node,,num,max
n,nmax+1,0,h_coil/2
type,5
real,11
e,nd_s,nmax+1
d,nmax+1,volt,0 ! ground
csys
eplo
fini
! *** solution
/solu
antype,trans
NROPT,FULL
time,tend
nsub,nsubs
outres,all,all
kbc,1 ! step applied load
solve
fini
! *** post-solution
/post26
Nsol,2,nd_p,volt,Vp
Nsol,3,nd_s,volt,Vs
dandelioo8197
突然看到这个 晓得你是谁了:D
2015年5月9日
