10 improperly defined surface(s). Please check your surface
浏览:10940
10 improperly defined surface(s). Please check your surface definitions. Make sure that all surface normals point outward.这是将hypermesh做的模型以inp格式导入abaqus,数据检查时出现的错误,哪个大神知道怎么解决?
