接触分析实例求教
浏览:7732 回答:4
《abaqus6.11有限元分析从入门到精通》教材第六章的一个实例,按着书上的步骤来的,警告信息提示:Path based tracking is defined in contact pair (assembly_surf-base-up,assembly_punch-1_surf-punch-down). Path based tracking cannot be used with analytical rigid master surfaces, the state based tracking algorithm will be used instead.求教各位大神,谢谢。
