亲们,帮我看下我的报错怎么纠正啊
浏览:12830
The material options *elastic, *fabric, *hyperelastic, *hyperfoam, *hypoelastic, and *porous elastic are mutually exclusive
*viscoelasticity requires the use of either *elastic, *hyperelastic, *anisotropic hyperelastic or *hyperfoam
2980 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection.
The elset, exterior or tracer set parameter is required on the *element output option for this output database history request
The nlgeom flag must be set on the *step option if a hyperelastic, a hyperfoam, or a fabric material is used.
Analysis Input File Processor exited with an error.
