第一次用Virtual LAB调用nastran计算模态的问题
浏览:14505 回答:2
最后计算时候不能正常进行,应该是调用出了点问题job details显示
XPR VERSION 12
Nastran Working Directory=C:\Program Files\LMS\working\
Nastran Command Line="C:\Program Files\LMS\NXNastran\8.5mp1\bin\nastran64w.exe" "C:\Program Files\LMS\working\nastran_modal_solution_1.dat" PROG=VLACM scr=yes notify=no bat=no news=no
Starting Nastran Solver at: Tu Sep 01 20:43:27 2015
Nastran Solver is running...
Nastran Solver finished at: Tu Sep 01 20:43:28 2015
XPR Service is retrieving Nastran results.
There are no log files at all.
In case of result files you need to check them manually.
If there are no result files you need to check the Nastran installation.
Nastran Solver finished with errors.
Nastran XPR Service finished at : Tu Sep 01 20:43:28 2015
有木有大神,指点一二啊····
XPR VERSION 12
有木有大神,指点一二啊····
