请教一下job计算时中止
浏览:15640
显示错误为
The model database "J:\abaqus\work\qiaomian.cae" has been opened.
The job input file "Job-2.inp" has been submitted for analysis.
Job Job-2: Analysis Input File Processor completed successfully.
ERROR in job messaging system: Error in connection to analysis
Error in job Job-2: The executable standard.exe aborted with system error code 1073741795. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job Job-2 aborted due to errors.
我看有大神说是以管理员身份运行,但依旧不行,怎么回事啊
