用LS-DYNA做热冲击时温度函数怎么施加
浏览:8005
EDLOAD,ADD,TEMP,0,DIAN,TIME,TEM, 0, , , , , 我是定义了时间温度数组,用上面的命令定义了,可是出现The 4th field (0) of EDLOAD,add,temp is ignored.
*** ERROR *** CP = 9.828 TIME= 22:04:13
The TOFFST command is either not available for this version of ANSYS or
the appropriate product was not selected for this session.
Contact your ANSYS support person for more information. ,请问各位高人,这该怎么解答,谢谢了。
