Abaqus error code65533求助!!!
浏览:15744 回答:1
The executable C:\Program aborted with system error code 65533. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. 出现这样的问题,[0] on acer
E:\flowresult\admin_Job-2_7748\Job-2.bat ended prematurely and may have crashed. exit code 0xc0000005
这个是模型数据存储路径的错误说明,感觉应该是软件和硬件的问题,希望各路大神相助!!!
大佬有没有解决,指导一下
