本人做静态裂缝导入隐式动态时,出现这个报错。被困扰了很久,请大家帮我看看。谢谢
浏览:5301
Initial level set may not be applied to imported elements 163 when the state parameter on the *import option is set yes
Initial level set may not be applied to imported elements 989 when the state parameter on the *import option is set yes
这个是报错,我的单元类型是tet C3D4..谢谢大家
