做接触变形时遇到的错误
浏览:4584
The ratio of deformation speed to wave speed exceeds 1.0000 in at least one element.this usually indicates an error with the model definition.
如上述错误提示,我的网格划分没有问题,材料属性参数设置也没有问题。错误出在哪?请大神不吝赐教~
