求助:用patran无法进行后处理,请用过《MSC.Dytran Workshop Examples
浏览:334065 回答:5
我参照《
MSC.Dytran Workshop Examples》上的例子进行练习,在patran进行前处理,再用dytran求解,求解之前,书中给出这样一个提示:
“ Step 24. Simulation on UNIX-platforms
The Dytran input deck will be named tapered_beam.dat which will be in your directory.
To run the job on Unix Platform, type in the following command in your working directory: dytran jid=tapered_beam"
请问“ dytran jid=tapered_beam”是什么意思?这一步如何操作?
我用windows系统下的dytrran进行处理,得到了结果文件,再用patran进行后处理,执行以下操作:
Step 26. Analysis: Read Archive File / Results / Translate
Read in the results by translating the ARCfile where the analysis results are stored
a. Analysis: Read Archive File / Results/ Translate.
b. Click Select Archive File.
c. Select and Add both TAPERED_BEAM_BEAM_0.ARC and TAPERED_BEAM_PLATE_0.ARC
d. Click Add.
e. Click Apply.
f. Click Apply.
在执行第f步时,给出提示
“ Message:Question from application MSC.Dytran
It is highly recommended to use the Attach option.Do you want to continue?”
如果继续执行,则会给出提示“ Acknowledgement requested from application DYTRANP3--Error Seeking in File.”
请问是什么原因造成的?
d. Click Add.
e. Click Apply.
f. Click Apply.
在执行第f步时,给出提示
请问是什么原因造成的?
