『求助』如何解决该问题?
浏览:160781 回答:1
大家好!我刚刚开始学习abquas,在按照一本教程步骤模拟一个问题,进行submit时,没有成功,并出现如下提示“The executable C:\\ABAQUS\\6.4-1\\exec\\pre.exeaborted with system error code 29539.Please check the .dat, .msg, and .sta files for error messages if the filesexist. If there are no error messages and you cannot resolve the problem,please run the command "abaqus job=support information=all" to report andsave your system information. Use the same command to run ABAQUS that youused when the problem occurred. Please contact your local ABAQUS supportoffice and send them the input file, the file support.log which you justcreated, the executable name, and the error code.”不知如何处理,恳请各位朋友指点!非常感谢!
**7757_hphH
好难过呀!怎么没人帮助!今天分析另外一个模型,提交作业时,遇到同样的问题,不知如何解决?我分析是否是软件没装好还是别的原因?请问有朋友遇到过这样的问题没有,怎么解决?感谢大家指点指点!
2007年9月16日
