HyperMesh快速入门.pdf
2009-08-26 评论:5 下载:1
下载
大小:73.00KB
见附件
When
you select by assems, HyperMesh displays a list of the
available assemblies from which you may select.
by comps Allows you to select the entities within or attached to a
component. When you select by comps, HyperMesh displays
a list of the available components.
节选段落二:
To exit HyperMesh:
1. Click return to access the main menu.
2. Click quit to end the HyperMesh session.
Methods of Selecting Entities Page 11 of 11
Rev. 5/9/96
Conclusion
This concludes the Methods of Selecting Entities lesson.
节选段落三:
Using the on plane method Page 182 in the HyperMesh Reference Manual.
(5条)
能不能搞一些经典的有用的信息呀,要对得起这个“CAE联盟”名字
谢谢楼主分享!!!!!!!!!!!!!
查看更多评论 >
