[BHRA fluid engineering series] Donald Stuart Miller - Internal Flow Systems (1978, Bhra Fluid Engineering) - libgen.lc.pdf
internal flow system,米勒先生所著,部分内容
In dcscribing systcin performance i t is appropriate to use differcnces'
in lcvcls iir Iiciiils cxpi-csscd iii meires of fluid. Low speed i r aiid gas ílows are usually.
I I I L . : L S L I ~ C ~ usiiig !iiaiii~iriciers which register pressures e. a displaccment of a fluid column.节选段落二:
Exccpt for Chaptcrs G and 7, o n cavitation and transielit ilow, tlie prcscnt work is rcstrictcd
to steady flow of a single phasc near Ncwtonian fluid.节选段落三:
Tlic iiiass pci- uiiit volunle is reícrred lo as the fluid d e n s i t y , ~ . Units o l density are:.
回复
