Hypermesh菜单上的关键字释意(按字母排序).doc
2011-07-12 评论:5 下载:6
下载
大小:33.50KB
HyperMesh Panels Listed Alphabetically
accels  Creates or updates accelerations.
align node  Projects nodes to an imaginary line passing through two nodes.
animation subpanel  Allows you to control the display of your model during animation.
apply result  Applies a displacement result to the nodes.
assemblies
节选段落二:
you to work interactively on mesh parameters.
axis labels  Edits axis label information.
axis scaling  Modifies plot axes.
bars  Creates or updates bar2 or bar3 elements.
beam xsect   Calculates beam section properties
border  Edits the border of an XY plot.
build menu  Redefines the layout of the HyperMesh
节选段落三:
to edit solver specific data on a set of entities.
collectors  Creates components that group data together.
color   Modifies the color attributes of collectors.
colors subpanel   Located on the options panel; controls user-interface colors.
command subpanel   Located on the files panel; executes a HyperMesh
(5条)
跟关键字手册上是一样的吗
这个资料不好 楼主不要骗回帖呀
查看更多评论 >
