Isight二次开发.pdf
2021-04-12 下载:12
下载
大小:1.77MB
Isight二次开发文档
and classes for manipulating Isight models.
节选段落二:
Both the source Java code
and a deployable EAR file are supplied, along with instructions for deployment (see the PDF
file in the examples/development/applications/ExampleJobMonitorMDB
directory).
Enabling Durable Messaging
By default, the messaging configuration of an MDB is non-durable.
节选段落三:
However, the full Isight API is not provided in this document. Once you get to
the point of writing the necessary classes and needing to use the Isight API, refer to the javadocs
found in your Isight installation to access a full HTML representation of the Isight API.
