FlowMaster.pdf
bentley flowmaster教程
............................................................................................................................... 1
(1) Opening Bentley FlowMaster ........................................................................................................... 1
(2) Using Bentley FlowMaster .节选段落二:
Procedure
Open the program by double-clicking the FlowMaster icon, seen below, on your desktop or click
Start > All Programs > Bentley > FlowMaster, and select FlowMaster.
Once you are in the program, you should see the welcome window pictured节选段落三:
Select the tab next to
Solve For: to view the channel variables FlowMaster can calculate. From these options select
Discharge.
Procedure
Discharge.
