adams振动分析实例.pdf
adams振动分析实例
Overview
ADAMS/Vibration, part of the MSC.ADAMS ? suite of software,
performs frequency-domain analyses. ADAMS/Vibration is a
plugin to the interface products ADAMS/Aircraft, ADAMS/Car,
ADAMS/Engine, ADAMS/Rail, and ADAMS/View. It can also be
used standalone with an ADAMS/Solver model.节选段落二:
In the UNIX environment, you start ADAMS/View from the MSC.ADAMS Toolbar and
then, from within ADAMS/View, you load the ADAMS/Vibration plugin.
In the Windows environment, you start ADAMS/View from the Start menu, and then load
the ADAMS/Vibration plugin.节选段落三:
Satellite
Solar
panels
Bus
Payload
adapter
Test
base
Getting Started Using ADAMS/Vibration
Building the Model12
Loading ADAMS/Vibration
Because ADAMS/Vibration is a plugin to ADAMS/Aircraft, ADAMS/Car,
ADAMS/Engine, ADAMS/Rail, and ADAMS/View, you need to load ADAMS/Vibration
when you use ADAMS/Vibration
Overview
Satellite
Solar
panels
Bus
Payload
adapter
Test
base
