Ls-dyna_tutorial.pdf
2021-08-16 下载:16
下载
大小:2.48MB
Ls-dyna_tutorial
Introduction
This tutorial presents all the steps taken, to model a front impact analysis, starting from an FE
double box beam structure, to Ls-Dyna FE-model output.
节选段落二:
Data files
The files required for this tutorial are:
 One Ls-Dyna [*.key] file containing the double box beam structure.
节选段落三:
 One Ls-Dyna [*.key] “Material database” file [material_database.key].
 One Ls-Dyna [*.key] file containing the barrier [barrier.key].
 One Header Ls-Dyna [*.key] file [header.key].
LS-DYNA DECK – Setting up a Model
BETA CAE Systems 5 ANSA Tutorials
2. Assembly & Welding management
2.1.
