Matlab之Simulink菜鸟级经典教程(手把手滴让你成为仿真高手).pdf
You can access these demos
from the Simulink block library window:
1 Type simulink3 in the MATLAB command window. The Simulink block
library window appears.
2 Double-click on the Demos icon. The MATLAB Demos window appears.节选段落二:
To terminate Simulink and MATLAB, choose Exit MATLAB (on a Microsoft
Windows system) or Quit MATLAB (on a UNIX system). You can also type
quit in the MATLAB command window. If you want to leave Simulink but not
terminate MATLAB, just close all Simulink windows.节选段落三:
Consult your MATLAB
documentation for more information. You can then start Simulink in two ways:
• Click on the Simulink icon on the MATLAB toolbar.
• Enter the simulink command at the MATLAB prompt.
On Microsoft Windows platforms, starting Simulink displays the Simulink
Library Browser.
Consult your MATLAB
Library Browser.
查看更多评论 >
