ProE与ANSYS有限元分析的相互转换.pdf
2006-08-27 评论:5 下载:2
下载
大小:863.02KB
ProE与ANSYS有限元分析的相互转换.供参考
Finite Element Method using
Pro/ENGINEER and ANSYS
Notes by R.W. Toogood
The transfer of a model from Pro/ENGINEER to ANSYS will be demonstrated here
for a simple solid model. Model idealizations such as shells and beams will not be
treated.节选段落二:
Copy the .ans file from your Pro/E working directory to the directory you will use for
running ANSYS.
Step 6. Importing into ANSYS
Launch ANSYS Interactive and select
File > Read Input From...
Select the .ans file you created previously. This will read in the entire model.节选段落三:
Running the ANSYS solver
In the ANSYS Main Menu on the left, select
Solution > Solve > Current LS > OK
After a few seconds, you will be informed that the solution is complete.
Step 8. Viewing the results
There are myriad possibilities for viewing FEM results.
treated.节选段落二:
running ANSYS.
查看更多评论 >
