A Short Introduction about LS DYNA and the LS PrePost.pdf
2019-05-16 评论:1 下载:83
下载
大小:823.08KB
关于LS-DYNA的入门指南,主要介绍了K文件的结构,以及建立一个完整模型并运算的简要过程。
英文版,入门级。
A Short Introduction to LS
DYNA and the Input file
LS DYNA
• The input file is called Key-file (.key or .k)
• A key-file is built up of keywords, which defines the problem
• Every keyword starts with *
• The Keyword is divided into columns and rows
• The format can be written in fixed or free format
节选段落二:
LS DYNA
• Important information about the different keywords can be found in LS DYNA
Keyword manual. (Example in Fig. 2)
Fig. 2. A page from the LS DYNA keyword
manual, where you find e.g. information about
the purpose of the keyword and what to input to
the keyword.
节选段落三:
Write the keyword name
Press to run
• If you want more information about LS DYNA you can read “Getting_Started in the
LS DYNA keyword manual.
(1条)
很适合入门
