Application of NVH Techniques to Engine Production Line Test.pdf
2006-12-07 评论:2 下载:4
下载
大小:600.62KB
SAE的论文,与大家共享
2005-01-2452
Alex Alvey
Tecumseh Products Company
Gabriella Cerrato Jay
MTS Systems Corp.
节选段落二:
Therefore the Cold Start test can be implemented for
100% of the production with far less penalty on line
throughput rate.
节选段落三:
Example of Cold Start Test display during test
The defects are identified by applying typical NVH signal
processing techniques to the signals acquired during the
test (1,7).
(2条)
Thanks a lot
dank schon!
