318258-GettingStartedWithLS-DYNA.pdf
2006-04-13 评论:4 下载:3
下载
大小:310.34KB
Getting Started With LS-DYNA.pdf比较经典!
Units
LS-DYNA requires a consistent set of units to be used. All parameters in this manual are in SI units.
节选段落二:
Getting Started
3.3 LS-DYNA solution
The vertical and horizontal displacement of node 7, calculated by LS-DYNA, are shown in the
following 2 graphs.
节选段落三:
The LS-
DYNA solution compares exactly with the analytical solution.
(4条)
Getting Started With LS-DYNA.pdf(献给初学者)
查看更多评论 >
