LS-dyna_常见问题汇总
2015年4月8日 浏览:14696 评论:11 收藏:7
1. LS-DYNA 简介......................................................................................................................................................1
2. 单位制度 .................................................................................................................................................................5
3. 质量缩放 .................................................................................................................................................................6
4. 长分析时间 .............................................................................................................................................................7
5. 准静态 .....................................................................................................................................................................8
6. 计算不稳定 .............................................................................................................................................................9
7. 负体积 ...................................................................................................................................................................10
8. 能量平衡 ...............................................................................................................................................................11
9. 沙漏控制 ...............................................................................................................................................................13
10. 阻尼 ...................................................................................................................................................................14
11. ASCII output for MPP via binout ......................................................................................................................15
12. 接触概述 ...........................................................................................................................................................16
13. Contact Soft 1 接触 Soft=1 ..............................................................................................................................17
14. LS-DYNA 中的接触界面模拟.........................................................................................................................18
15. LS-DYNA 中夹层板(sandwich)的模拟 ...........................................................................................................25
16. 怎样进行二次开发 ...........................................................................................................................................26
17. 如何实现程序的连续计算 ...............................................................................................................................27
18. 如何得知 LS-DYNA 为一套完整的软件? ....................................................................................................28
19. LS-DYNA 与市面上其它的前处理软件兼容性如何? .................................................................................28
20. LS-DYNA 似乎很重视「 Contact Algorithm」,这是为什幺? .....................................................................28
21. 如果要利用 LS-DYNA 进行 MPP(平行运算)的计算,硬件配备及操作系统有无特殊需求? .................28
22. FEMB 能够自动产生有限元素网格吗? ........................................................................................................28
23. 实际的产品 CAD 图文件,有许多复杂的几何造型,这些 feature 是否都该纳入分析考量? ................28
24. LS-DYNA 是否只能进行壳元素的分析? .....................................................................................................29
25. 在 LS-DYNA 里该如何强制刚体运动? ........................................................................................................29
26. 在 LS-POST 如何显示应变分布图? ..............................................................................................................29
27. 强制结构体绕着特定轴旋转的时候,为何会出现奇怪的变形? ................................................................29
28. LS-DYNA 该如何进行振动模态的分析设定? .............................................................................................30
29. 究竟采用 Implicit 及 Explicit 的分析方式会有多大的差异性? ..................................................................30
30. 要如何设定才能让 LS-DYNA 自动进行 Implicit / Explicit 的切换? ..........................................................30
31. LS-DYNA 是唯一能够将 Implicit 与 Explicit code 整合在一起的软件,这对实际的分析工作有何帮助?
30
32. 请问以 Explicit 方式进行分析,影响运算时间的因素有哪些? .................................................................30
33. 势流科技您好,请问弹簧/阻尼系统该采用什幺元素来仿真比较恰当? ...................................................31
34. 请问安装 LS-DYNA(MPP)版本时,操作系统需有哪些额外的设定? .......................................................31
35.
30
35.
