这是怎么回事啊,
浏览:194434 回答:1
运行出现下面警告:
The strain increment has exceeded fifty times the strain to cause first yield at 337 points
check the incremental size in your input file. It probably happened during the transition from elastic to plastic zone
2008年5月10日
