请教:组件受力文件怎么看,力是多少?
浏览:178588 回答:6
在磁场分析时定义了一个组件,最后
FMAGSUM,'ARM'
得到的文件内容如下,请问怎么算组件的受力啊,就是像平常所说的是多少牛啊?
sum of forces and torques on selected nodes
force : F = 0.38639E-13 -0.73639E-15 0.73733E-14 0.39343E-13
torque: T = 0.97013E-16 0.10717E-14 0.86675E-17 0.10761E-14
force components are available in _fxsum,_fysum,_fzsum,_fssum parameters
torque components are available in _txsum,_tysum,_tzsum,_tssum parameters
force is in RSYS; torque is in local Cartesian (shifted/rotated RSYS)
LISTING OF THE DATA ON FILE emft.out
(6)
马小跳
请问,楼主,你的力矩是如何计算的?可否提供相关命令流或者GUI操作方式,谢谢!
2014年6月15日
急呀,还有几天就要毕业答辩了,这个问题还解决不掉,眼看要挂了啊!请大家帮帮忙啊!!!
2008年6月11日
真的很纳闷啊!力应该很大才对呀!大家帮我看看啊!我不会命令,下面是从后面拷过来的指令,能帮助我看一下是怎么回事吗?
/title,3d
/file,3d
/NOPR
/PMETH,OFF,1
KEYW,PR_SET,1
KEYW,PR_STRUC,0
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,1
KEYW,MAGNOD,1
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
KEYW,PR_CFD,0
/GO
/PREP7
et,1,solid117
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,1,,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,2,,0.9999
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,3,,1.0997785406
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MGXX,3,,0
MPDATA,MGYY,3,,8.9e+005
MPDATA,MGZZ,3,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,4,,4000
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,MURX,5,,636
CYLIND,0.008, ,0,0.03,0,360,
BLOCK,-0.013,0.013,-0.013,0.013,0,0.03,
VSBV, 2, 1
BLOCK,-0.002,0.002,-0.013,0.013,0,0.03,
VSBV, 3, 1
VSBV, 1, 3
FLST,2,5,6,ORDE,4
FITEM,2,1
FITEM,2,-2
FITEM,2,4
FITEM,2,-6
VGLUE,P51X
BLOCK,-0.025,0.025,-0.0135,-0.0235,-0.01,0.04,
CYLIND,0.05, ,-0.02,0.05,0,360,
FLST,2,7,6,ORDE,4
FITEM,2,1
FITEM,2,-3
FITEM,2,7
FITEM,2,-10
VOVLAP,P51X
NUMCMP,VOLU
/SHOW,WIN32
/DEVICE,VECTOR,1
/DEVICE,BBOX,1
/DEVICE,DITHER,1
/DEVICE,ANIM,BMP
! /UIS,DYNA,0
! /UIS,ZPIC,0
/REPLOT
CM,_Y,VOLU
VSEL, , , , 1
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 5, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , , 3
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 1, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,6,ORDE,2
FITEM,5,2
FITEM,5,4
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 2, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,VOLU
VSEL, , , , 5
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 3, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,6,ORDE,2
FITEM,5,6
FITEM,5,-7
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT, 4, , 1, 0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SMRT,6
SMRT,5
MSHAPE,1,3D
MSHKEY,0
FLST,5,7,6,ORDE,2
FITEM,5,1
FITEM,5,-7
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/PNUM,KP,0
/PNUM,LINE,0
/PNUM,AREA,0
/PNUM,VOLU,0
/PNUM,NODE,0
/PNUM,TABN,0
/PNUM,SVAL,0
/NUMBER,0
/PNUM,MAT,1
/REPLOT
ALLSEL,ALL
ESEL,S,MAT,,5
CM,arm,ELEM
ALLSEL,ALL
FMAGBC,'ARM'
FINISH
/SOL
MAGSOLV,0,3,0.001, ,25,
FINISH
/POST1
/VSCALE,1,1,0
PLVECT,B, , , ,VECT,ELEM,ON,0
FMAGSUM,'ARM'
2008年6月11日
谢谢楼,我的怎么会出现负值呢?
2008年6月10日
jodan
定义组件
asel,s,,,2
ESLA,S
CM,dingzi,ELEM
FMAGBC,'dingzi'
后处理查看结果
fmagsum,'dingzi'
http://shop35317843.taobao.com/
http://shop.paipai.com/394635313
2008年6月10日
用的单位体系MKS
2008年6月8日
