warnings
浏览:90365 回答:1
做接触分析时,出现一大堆的warning信息:
Tangent directions used to enforced contact constraints for contact pair (assembly__pickedset27_cns_,assembly__pickedsurf26) will not rotate with either surface.
k
还有:
Abaqus is unable to estimate an average interface element length. The whole model characteristic element length is used instead.
这些对计算结果有影响吗?
2008年7月10日
评论 点赞 1
