做了一个简单模型,为什么划分网格时出现warning呢?
浏览:181016 回答:8
我做了一个模型,对其进行了自由划分,但提示出错Shape testing revealed that 1 of the 3715 new or modified elements violate shape warning limits. To review test results, please see the
output file or issue the CHECK command. ,请教达人什么原因呢?多谢!
还有就是用mapped也不行,说是Area 5 is irregular. Cannot be map meshed with quadrilaterals.,请教原因
log文件如下:
/PREP7
ET,1,PLANE67
PCIRC,0.0295,0,0,360,
PCIRC,0.0305,0.0295,0,360,
PCIRC,0.0459,0.0305,0,360,
PCIRC,0.047,0.0459,0,360,
FLST,2,4,5,ORDE,2
FITEM,2,1
FITEM,2,-4
AGLUE,P51X
MPTEMP,,,,,,,,
MPTEMP,1,388
MPTEMP,2,408
MPTEMP,3,423
MPTEMP,4,438
MPTEMP,5,463
MPTEMP,6,483
MPDATA,KXX,1,,0.131
MPDATA,KXX,1,,0.134
MPDATA,KXX,1,,0.139
MPDATA,KXX,1,,0.141
MPDATA,KXX,1,,0.152
MPDATA,KXX,1,,0.158
MPTEMP,,,,,,,,
MPTEMP,1,373
MPTEMP,2,423
MPTEMP,3,473
MPTEMP,4,523
MPTEMP,5,573
MPTEMP,6,623
MPTEMP,7,673
MPDATA,C,1,,1385
MPDATA,C,1,,1385
MPDATA,C,1,,1341
MPDATA,C,1,,1323
MPDATA,C,1,,1307
MPDATA,C,1,,1293
MPDATA,C,1,,1282
MPTEMP,,,,,,,,
MPTEMP,1,373
MPTEMP,2,423
MPTEMP,3,473
MPTEMP,4,523
MPTEMP,5,573
MPTEMP,6,623
MPTEMP,7,673
MPDATA,DENS,1,,0.928
MPDATA,DENS,1,,0.915
MPDATA,DENS,1,,0.903
MPDATA,DENS,1,,0.891
MPDATA,DENS,1,,0.879
MPDATA,DENS,1,,0.866
MPDATA,DENS,1,,0.854
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,RSVX,2,,500
MPTEMP,,,,,,,,
MPTEMP,1,300
MPTEMP,2,680
MPDATA,KXX,2,,3.0
MPDATA,KXX,2,,2.9
MPTEMP,,,,,,,,
MPTEMP,1,300
MPTEMP,2,680
MPDATA,C,2,,1143
MPDATA,C,2,,1323
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,2,,3200
MPTEMP,,,,,,,,
MPTEMP,1,388
MPTEMP,2,408
MPTEMP,3,423
MPTEMP,4,438
MPTEMP,5,463
MPTEMP,6,483
MPDATA,KXX,3,,0.131
MPDATA,KXX,3,,0.134
MPDATA,KXX,3,,0.139
MPDATA,KXX,3,,0.141
MPDATA,KXX,3,,0.152
MPDATA,KXX,3,,0.158
MPTEMP,,,,,,,,
MPTEMP,1,373
MPTEMP,2,423
MPTEMP,3,473
MPTEMP,4,523
MPTEMP,5,573
MPTEMP,6,623
MPTEMP,7,673
MPDATA,C,3,,1385
MPDATA,C,3,,1385
MPDATA,C,3,,1341
MPDATA,C,3,,1323
MPDATA,C,3,,1307
MPDATA,C,3,,1293
MPDATA,C,3,,1282
MPTEMP,,,,,,,,
MPTEMP,1,373
MPTEMP,2,423
MPTEMP,3,473
MPTEMP,4,523
MPTEMP,5,573
MPTEMP,6,623
MPTEMP,7,673
MPDATA,DENS,3,,0.928
MPDATA,DENS,3,,0.915
MPDATA,DENS,3,,0.903
MPDATA,DENS,3,,0.891
MPDATA,DENS,3,,0.879
MPDATA,DENS,3,,0.866
MPDATA,DENS,3,,0.854
MPTEMP,,,,,,,,
MPTEMP,1,293
MPTEMP,2,373
MPTEMP,3,673
MPDATA,KXX,4,,16.33
MPDATA,KXX,4,,16.75
MPDATA,KXX,4,,20.52
MPTEMP,,,,,,,,
MPTEMP,1,293
MPTEMP,2,363
MPTEMP,3,473
MPTEMP,4,593
MPTEMP,5,703
MPTEMP,6,813
MPDATA,C,4,,452
MPDATA,C,4,,486
MPDATA,C,4,,528
MPDATA,C,4,,548
MPDATA,C,4,,565
MPDATA,C,4,,573
MPTEMP,,,,,,,,
MPTEMP,1,293
MPTEMP,2,363
MPTEMP,3,473
MPTEMP,4,593
MPTEMP,5,703
MPDATA,DENS,4,,795
MPDATA,DENS,4,,792
MPDATA,DENS,4,,788
MPDATA,DENS,4,,783
MPDATA,DENS,4,,779
MPTEMP,,,,,,,,
MPTEMP,1,373
MPTEMP,2,423
MPTEMP,3,473
MPTEMP,4,523
MPTEMP,5,573
MPTEMP,6,623
MPTEMP,7,673
MPDE,KXX,1
MPDATA,KXX,1,,869
MPDATA,KXX,1,,844
MPDATA,KXX,1,,820
MPDATA,KXX,1,,796
MPDATA,KXX,1,,771
MPDATA,KXX,1,,747
MPDATA,KXX,1,,722
MPTEMP,,,,,,,,
MPTEMP,1,373
MPTEMP,2,423
MPTEMP,3,473
MPTEMP,4,523
MPTEMP,5,573
MPTEMP,6,623
MPTEMP,7,673
MPDE,DENS,1
MPTEMP,,,,,,,,
MPTEMP,1,300
MPTEMP,2,680
MPDE,KXX,2
MPDATA,KXX,2,,3
MPDATA,KXX,2,,2.9
MPTEMP,,,,,,,,
MPTEMP,1,400
MPTEMP,2,420
MPTEMP,3,440
MPTEMP,4,460
MPTEMP,5,480
MPTEMP,6,500
MPTEMP,7,540
MPTEMP,8,580
MPTEMP,9,620
MPTEMP,10,660
MPTEMP,11,700
MPTEMP,12,710
MPDE,DENS,3
MPDATA,DENS,3,,1798.2
MPDATA,DENS,3,,1781.3
MPDATA,DENS,3,,1771
MPDATA,DENS,3,,1763.7
MPDATA,DENS,3,,1751.5
MPDATA,DENS,3,,1739.3
MPDATA,DENS,3,,1714.9
MPDATA,DENS,3,,1690.5
MPDATA,DENS,3,,1666.1
MPDATA,DENS,3,,1641.6
MPDATA,DENS,3,,1617.2
MPDATA,DENS,3,,1611.1
MPTEMP,,,,,,,,
MPTEMP,1,393
MPTEMP,2,423
MPTEMP,3,443
MPTEMP,4,473
MPTEMP,5,523
MPTEMP,6,553
MPTEMP,7,573
MPTEMP,8,593
MPDE,C,3
MPDATA,C,3,,966
MPDATA,C,3,,993
MPDATA,C,3,,1396
MPDATA,C,3,,1152
MPDATA,C,3,,1109
MPDATA,C,3,,1113
MPDATA,C,3,,1118
MPDATA,C,3,,1132
MPTEMP,,,,,,,,
MPTEMP,1,388
MPTEMP,2,408
MPTEMP,3,423
MPTEMP,4,438
MPTEMP,5,463
MPTEMP,6,483
MPDE,KXX,3
MPDATA,KXX,3,,0.131
MPDATA,KXX,3,,0.134
MPDATA,KXX,3,,0.139
MPDATA,KXX,3,,0.141
MPDATA,KXX,3,,0.152
MPDATA,KXX,3,,0.158
MPTEMP,,,,,,,,
MPTEMP,1,373
MPTEMP,2,423
MPTEMP,3,473
MPTEMP,4,523
MPTEMP,5,573
MPTEMP,6,623
MPTEMP,7,673
MPDE,DENS,1
MPDATA,DENS,1,,928
MPDATA,DENS,1,,915
MPDATA,DENS,1,,903
MPDATA,DENS,1,,891
MPDATA,DENS,1,,879
MPDATA,DENS,1,,866
MPDATA,DENS,1,,854
MPTEMP,,,,,,,,
MPTEMP,1,373
MPTEMP,2,423
MPTEMP,3,473
MPTEMP,4,523
MPTEMP,5,573
MPTEMP,6,623
MPTEMP,7,673
MPDE,C,1
MPDATA,C,1,,1385
MPDATA,C,1,,1385
MPDATA,C,1,,1341
MPDATA,C,1,,1323
MPDATA,C,1,,1307
MPDATA,C,1,,1293
MPDATA,C,1,,1282
SAVE,'model','db','D:\ansys\'
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 1, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 5
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 2, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 6
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 3, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , , 7
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 4, , 1, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SAVE,'mesh','db','D:\ansys\'
SMRT,6
SMRT,3
MSHAPE,0,2D
MSHKEY,1
FLST,5,4,5,ORDE,3
FITEM,5,1
FITEM,5,5
FITEM,5,-7
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FLST,5,4,5,ORDE,3
FITEM,5,1
FITEM,5,5
FITEM,5,-7
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
SMRT,3
MSHKEY,0
FLST,5,4,5,ORDE,3
FITEM,5,1
FITEM,5,5
FITEM,5,-7
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
SAVE,'mesh2','db','D:\ansys\'
MSHKEY,1
FLST,5,4,5,ORDE,3
FITEM,5,1
FITEM,5,5
FITEM,5,-7
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
ACLEAR,_Y1
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
! /EXIT,NOSAV
(8)
我也有相同的问题,5555555555
2009年6月6日
bazhuzhixin
多谢版大,我以前也这样试过,就是先划分最内层的圆,然后划分外面的,但计算结果完全和预期值不符,但可能是我其他步骤有问题,如载荷的施加,我准备用两种模型都做一下模拟,看那个更适合实际情况
再次表示感谢!
2008年10月13日
启航
在划分网格的时候先划分比较小的面,让比较大的面来适应比较小的面,我用你的模型进行划分了,划分记过如图所示。这里是自由网格划分和映射网格划分相结合的。
2008年10月13日
bazhuzhixin
关键这里是四个同心圆,我看有划分圆的是先把边划分然后进行面划分,搞不明白了
2008年10月10日
启航
你说的对着呢,多于4条边的情况下是不能用映射网格划分,但是可以创建一些线把这个面分割成能映射划分的形式。或者就是用四边形自由网格划分,这个没有边数的限制,只要是平面的图形也可以处理的很好
2008年10月10日
bazhuzhixin
原帖由 jiangfeng 于 2008-10-9 8:27:00 发表
首先你使用的是智能网格划分,这个划分方法比较傻瓜化。对于分析的单元是2d平面单元,一般都定义成平面,对于2d的问题用映射网格划分可以得到很好的结果。你可以试试。
谢谢斑竹大大,我这里划分就是不能用映射划分,提示error,我查书好像是说映射划分的面必须是三边形或四边形
2008年10月9日
启航
2008年10月9日
只有一个单元超标,对求解精度影响很小。
如果要重新划分,调整一下网格划分的尺寸应该就可以解决了。
2008年10月8日
