求助dynaform分析报错的原因
浏览:77985 回答:5
在dynaform分析中,我用的是5.5的,在多工步中,我第一序中分析没有问题,但是到第2序的时候,我把第1序的结果导入到2序中分析时出现
*** WARNING warpage angle of element 285388 is 2.9091E+01 degrees
*** WARNING warpage angle of element 286540 is 4.0151E+01 degrees
*** WARNING warpage angle of element 286576 is 2.3168E+01 degrees
*** WARNING warpage angle of element 292020 is 2.0338E+01 degrees
*** WARNING warpage angle of element 292022 is 2.1019E+01 degrees
*** WARNING warpage angle of element 292104 is 2.0506E+01 degrees
*** WARNING warpage angle of element 292310 is 2.1339E+01 degrees
*** WARNING warpage angle of element 292316 is 2.0344E+01 degrees
*** WARNING warpage angle of element 292330 is 2.0334E+01 degrees
*** WARNING warpage angle of element 297148 is 2.0255E+01 degrees
*** WARNING warpage angle of element 297170 is 2.0314E+01 degrees
*** WARNING warpage angle of element 297191 is 2.1462E+01 degrees
*** WARNING warpage angle of element 297203 is 2.1007E+01 degrees
*** WARNING warpage angle of element 297259 is 2.0463E+01 degrees
*** WARNING warpage angle of element 297355 is 2.1134E+01 degrees
*** WARNING warpage angle of element 298032 is 2.0185E+01 degrees
*** WARNING warpage angle of element 298043 is 2.1036E+01 degrees
*** WARNING warpage angle of element 298067 is 2.0362E+01 degrees
*** WARNING warpage angle of element 298087 is 2.0685E+01 degrees
*** WARNING warpage angle of element 298124 is 2.2275E+01 degrees
*** WARNING warpage angle of element 311184 is 2.0344E+01 degrees
*** WARNING warpage angle of element 311458 is 2.0181E+01 degrees
*** WARNING warpage angle of element 312884 is 2.2589E+01 degrees
*** WARNING warpage angle of element 312890 is 2.0523E+01 degrees
*** WARNING warpage angle of element 312939 is 2.1185E+01 degrees
*** WARNING warpage angle of element 314847 is 2.0194E+01 degrees
*** WARNING warpage angle of element 314875 is 2.0532E+01 degrees
*** WARNING warpage angle of element 314903 is 2.1862E+01 degrees
*** WARNING warpage angle of element 314998 is 2.2161E+01 degrees
*** WARNING warpage angle of element 315000 is 2.1796E+01 degrees
*** WARNING warpage angle of element 317651 is 2.1337E+01 degrees
但是能够继续分析,请问各位大虾是什么原因,还有就是,如果让他继续分析,结果会失真吗,所出错的单元全部是BLANK上面的
