请高手不吝赐教(1):-)
浏览:165237 回答:2
问题是这样的:提交作业后,警告框中有如下的信息:“
The aspect ratio for 1500 elements exceeds 100 to 1. The elements have been identified in element set WarnElemAspectRatio.
The strain increment has exceeded fifty times the strain to cause first yield at 1 points
The strain increment has exceeded fifty times the strain to cause first yield at 11 points
The system matrix has 21 negative eigenvalues.
The strain increment has exceeded fifty times the strain to cause first yield at 18 points
Excessive distortion at a total of 21 integration points in solid (continuum) elements
The strain increment has exceeded fifty times the strain to cause first yield at 4 points
The system matrix has 3 negative eigenvalues.
The strain increment has exceeded fifty times the strain to cause first yield at 12 points
The system matrix has 25 negative eigenvalues.
The strain increment has exceeded fifty times the strain to cause first yield at 14 points
Excessive distortion at a total of 20 integration points in solid (continuum) elements
The strain increment has exceeded fifty times the strain to cause first yield at 3 points
The system matrix has 9 negative eigenvalues.
The strain increment has exceeded fifty times the strain to cause first yield at 8 points
Excessive distortion at a total of 12 integration points in solid (continuum) elements
The system matrix has 4 negative eigenvalues.
The system matrix has 14 negative eigenvalues.
The strain increment has exceeded fifty times the strain to cause first yield at 9 points
Excessive distortion at a total of 1 integration points in solid (continuum) elements
The system matrix has 1 negative eigenvalues.
The strain increment has exceeded fifty times the strain to cause first yield at 7 points
Excessive distortion at a total of 2 integration points in solid (continuum) elements
The strain increment has exceeded fifty times the strain to cause first yield at 5 points
Excessive distortion at a total of 13 integration points in solid (continuum) elements
The system matrix has 13 negative eigenvalues.
Excessive distortion at a total of 17 integration points in solid (continuum) elements”
显然总结一下,除了各句中的具体数字不同这外,主要有以下几个句型:
第一句:The aspect ratio for 1500 elements exceeds 100 to 1. The elements have been identified in element set WarnElemAspectRatio.
第二句:The strain increment has exceeded fifty times the strain to cause first yield at 11 points
第三句:The system matrix has 21 negative eigenvalues.
第四句:The strain increment has exceeded fifty times the strain to cause first yield at 18 points
第五句:Excessive distortion at a total of 21 integration points in solid (continuum) elements
请问各位高手,这主要是什么意思?是不是我的网格分的不好?
emtfemtf
十分感谢:-)。
2008年12月23日
winken
原帖由 emtfemtf 于 2008-12-13 17:44:00 发表
意思已经很清楚明了,我箱这些英语单词的汉语翻译您也很清楚,就是您的网格划分质量问题,建议您找一份网格质量控制参数解释的资料,您会很清楚您的问题所在,建议去看一下《HYPERMESH从入门到精通》一书,上面的某个章节上有关于aspect ratio等参数的解释
2008年12月15日
