hypermesh错误2203怎么改?
浏览:100757 回答:2
如题,貌似是网格的错误。
查看out文件是这样的:
ITERATION 0
Element No. 163 Element Type = TRIA3
WARNING - Outside of recommended range: Vertex Angle = 11.591
lower limit = 15.000
Element No. 164 Element Type = TRIA3
Element No. 165 Element Type = TRIA3
NOTE : other similar error/warning messages were suppressed,
use PARAM,CHECKEL,FULL to obtain full report
Element No. 331 Element Type = TRIA3
WARNING - Outside of recommended range: Skew Angle = 78.301
upper limit = 75.000
Element No. 332 Element Type = TRIA3
WARNING - Outside of recommended range: Skew Angle = 80.952
Element No. 333 Element Type = TRIA3
WARNING - Outside of recommended range: Skew Angle = 79.040
Element Quality Check Summary
Total # of elements that exceeded recommended range (warning) = 3524
我用element check 检查了以后还是不行啊。。
请问下各位前辈应该怎么改啊?
老是计算出错
谢谢
yyyyha
还不懂,进来也学学,那位老大帮帮忙
2009年4月12日
ucsicon
刚学,还不太懂呀:) :)
2009年4月1日
